If I have a detail who’s CPlane is rotated relative to World, when I try and get a quad OSnap, I would expect it to respect that detail’s CPlane, but it always defaults to world. I would find it much more handy for it to determine the Quad OSnap by the detail’s CPlane.
Second request (an oldie but a goodie), restoring saved CPlanes in details only works if Options → Modeling Aids CPlane is set to standard. It would be nice if I could restore a CPlane in a detail no matter how this is set.
Last request, it would be very handy if when I saved a NamedCPlane, it’s corresponding Front, Right, Left, Back, Bottom could be accessible as sub-CPlanes (similar to sub-layers) in the Named CPlane panel. This would make detailing out oddly aligned parts easier.
This is not how quad OSnap behaves in model space. Create a circle, mark its CrtStart, note where you get Quad OSnap. Rotate your CPlane some arbitrary amount on the Z axis, now check quad OSnap. The Quad OSnaps will have change relative to CrvStart and now will be giving you quad based on your new CPlane. It seems like this should be true for details as well.
Thank you for the logging the request and pointing out FromDetail. That is quite handy.
you’re totally right, I didn’t know that,
in that case, yes this should work the same in layout space RH-98483 Quad doesn’t align to Cplane in layout space
