[Q]How to stop Grasshopper from calculating forcibly?
Sometimes Grasshopper is calculating continuously for kids of reasons.This situation occurred usually especially when the def was complex.Is there any way to stop Grasshopper from calculating forcibly?It seems that pressing esc do not work.And I do not want to end the whole progress from the Task Manager of Windows.
you can try pressing the ESC key for a few seconds: if the calculation involves one single component, ESC usually works (at least for me)
if the calculation involves like 20 components, then CTRL+ALT+CANC is probably a better way
Are you experiencing this while using the new Grasshopper Rhino components?
Thanks.I will give a try when this situation occurs next time.
No. In fact, for me,It is just because I mistakenly linked input and output which may contain complex data tree. I should be more careful next time and save def more frequently to reduce lose.
