Python3 : Running doctests
Trying to run doctest, I get the error :
‘RhinoCodePythonEngineIO’ object has no attribute ‘encoding’
I tried using unicode docstrings but no cigar. Is there a way to hack this without forking doctest?
Hi @capitaine_fred,
What version of Rhino? If Rhino 8, are you using Python2 or Python3?
You might want to post the script, or a small script that can be run by others, that repeat the issue.
– Dale
Hi @dale,
This is Rhino8, python3.
In foo.py i have :
def foo(x):
    """ Increment x.
    >>> foo(1)
    2
    >>> foo(42)
    43
    return  x + 1
and in foo_tests.py :
import unittest
import doctest
import inspect
from foo import foo
class Foo_Tests(unittest.TestCase):
    def test_foo_0(self):
        result = foo(0)
        expected = 1
        self.assertEqual(result, expected)
    def test_docstring(self):
       mod = inspect.getmodule(foo)
       doctest_results = doctest.testmod(mod)
       assert doctest_results.failed == 0
if __name__ == "__main__":
    suite = unittest.TestLoader().loadTestsFromTestCase(Foo_Tests)
    unittest.TextTestRunner(verbosity=2).run(suite)
Resulting in :
test_docstring (__main__.Foo_Tests) ... ERROR
test_foo_0 (__main__.Foo_Tests) ... ok
ERROR: test_docstring (__main__.Foo_Tests)
Traceback (most recent call last):
  File "file:///C:/Users/Work/Desktop/Doctests_test/foo_tests.py", line 19, in test_docstring
  File "doctest.py", line 1954, in testmod
  File "doctest.py", line 1450, in run
AttributeError: 'RhinoCodePythonEngineIO' object has no attribute 'encoding'
Ran 2 tests in 0.015s
FAILED (errors=1)
Fred.
I have run into the exact same problem. R8.7. Is there any solution to this?
Thank you
Axel
