Python3 component error in Revit2027
Hi @Japhy,
recently I have encountered an issue to initialize “Python 3.9.10” with RiR in Revi2027.
Rhino Version: Version 8 SR32
(8.32.26160.13001, 2026-06-09)
RiR version:
I could initialize it in standalone Rhino8 when I load ScriptEditor and GH python3 component works well in Grasshopper. The error is appearing only in Rhino.Inside.Revit environment.
Does anybody have similar issue?
Thank you in advance.
Best wishes,
Junghwo
Running ok here in a newer version of Rhino.
A couple things to try besides updating would be to isolate from plugins (ladybug,..) , and reset your python env by closing all Rhinos and deleting the %HOMEPATH%\.rhinocode and start Rhino
  • Run ScriptEditor command and let it initialize languages
  • Run RhinoCodeLogs, save the logs into a text file
This might give you some idea. Probably IT Challenges
Hi @Japhy
Hi @MSAwan
Thank you for your help.
I have renamed .rhinocode folder first and initialize python3 in standalone Rhino8.
Rhino8 was installing all dependencies but Rhino8 inside Revit did not installed it.
I renamed .rhinocode folder second time, and right after open RiR and initialize the python installations in Revit again. New .rhinocode folder was generated and now python components Grasshopper in Revit works well.
Thanks again for your help!!
Best
Junghwo
