I get this error which I still cannot solve, I try with old ghpython in Rhino7 and it’s working good, but python3 grasshopper in Rhino8 seem can’t link to tekla
import clr
clr.AddReference(r"C:\TeklaStructures\2022.0\bin\Tekla.Structures.dll")
clr.AddReference(r"C:\TeklaStructures\2022.0\bin\Tekla.Structures.Plugins.dll")
clr.AddReference(r"C:\TeklaStructures\2022.0\bin\Tekla.Structures.Model.dll")
import Tekla.Structures.Model as md
model = md.Model()
a = model.GetInfo().NorthDirection
System.TypeInitializationException: The type initializer for ‘Tekla.Structures.ModelInternal.DelegateProxy’ threw an exception.
I’m just new in python 3 , I tried to fix it, but couldn’t. Can’t find choose unit .NET Framework or .Net Core
Any example code for this ? or C# in grasshopper Rhino8
Thank for your time.
@Shank let’s figure out if this is an internal problem in Tekla dll first. Are you using these dlls in a dotnet plugin? Let’s run this C# script to see if they work:
// r "C:\TeklaStructures\2022.0\bin\Tekla.Structures.dll"
// r "C:\TeklaStructures\2022.0\bin\Tekla.Structures.Plugins.dll"
// r "C:\TeklaStructures\2022.0\bin\Tekla.Structures.Model.dll"
using System;
using Tekla.Structures;
var model = new Model();
Console.WriteLine($"{model.GetInfo().NorthDirection}");
