park
(Junghwo Park)
November 5, 2026, 11:19am
1
@Japhy
I have recently installed RiR version below:
I having an issue to load python3.9.10 in RiR Revit 2027. You can see the Revit build and RiR version from above screenshot.
I have deleted %USERPROFILE%\.rhinocodefolder and initialized again.. Unfortunately, i fails in RiR.
The same RiR version in Revit 2024.3, I could load python3.9.10 and also standalone Rhino v8 I could load python3.9.10
Can this be a bug for the recent dailybuild of RiR?
Thanks in advance.
Japhy
(Japhy)
November 5, 2026, 12:20pm
2
Nothing inherently wrong, I’ll try the latest.
Japhy
(Japhy)
November 5, 2026, 12:48pm
3
Please run the RhinoCodeLogs command and post the results.
or grab the file from here.. %USERPROFILE%.rhinocode\logs\
park
(Junghwo Park)
November 5, 2026, 1:18pm
4
Japhy:
RhinoCodeLogs
Hi @Japhy
Thank you for your reply.
I have paste .rhinocode_backup from the older status.. after that python3.9.10 is now loaded in Revit 2027.
I will PM you the RhinoCodeLogs.
Thank you.
park
(Junghwo Park)
November 5, 2026, 1:40pm
5
Hi @Japhy ,
bad luck.. I have restarted Revit 2027 and run RiR.
I cannot load python3.9.10 again.
Japhy
(Japhy)
November 5, 2026, 1:55pm
6
Thanks for the log.
This looks to be getting tripped up Autodesk Desktop Connector, do you have that plugin loaded in Rhino?
Error Initializing Python | Error loading CPython engine
---> Python.Runtime.InternalPythonnetException: Failed to create Python type for AcWebServices
---> System.IO.FileNotFoundException: Could not load file or assembly 'DesktopConnectorInterop, Version=26.0.0.0'
park
(Junghwo Park)
November 5, 2026, 2:17pm
7
Thank you for the reply.
when I check RiR and search for plugin Desktop, there is no plugin for it.
I will try to install Revit 2027.3
Maybe this will help?
Japhy
(Japhy)
November 5, 2026, 2:20pm
8
What plugins that do not ship with Rhino do you have installed?
park
(Junghwo Park)
November 5, 2026, 2:26pm
9
here is screenshot.
but this problem occurs only in revit 2027.. in Revit 2024.3 I do not have same problem.
Japhy
(Japhy)
November 5, 2026, 2:32pm
10
Revit 2027 is in a different runtime than 2024 (4.8). Let’s disable third party plugins to try to isolate the issue.
park
(Junghwo Park)
November 5, 2026, 3:19pm
11
I have updated to Revit 2027.3.
launch RiR
disabled all plugins that not shiped with Rhino
ScriptEditor
Unfortunately, python3 failed to load.
Japhy
(Japhy)
November 5, 2026, 5:15pm
12
Repeated and youtrack filed. Thanks for reporting.. RH-100050 Python 3 fails after Revit 2027 DWG import
Japhy
(Japhy)
November 6, 2026, 4:13pm
13
The fix is in this mornings 8.x build, sending you a link for testing.
park
(Junghwo Park)
November 6, 2026, 6:54pm
14
Hi @Japhy ,
it works with new build you sent me 8.x
as always, thank you very much for your support!!
Best wishes,
Junghwo Park
brian
(Brian Gillespie)
November 10, 2026, 11:23pm
15
