Python Scripting - multiprocessing.spawn
Hello, I am getting this error in python for GH, what is the issue here, can someone help me?
Hi @Gowtham_Jeyabalan1,
Can you share some source code?
Thanks,
– Dale
i am using a spatial analysis python library called topologicpy, and i am trying to set dictionaries and i am getting this error
The error particularly occurs when i add the trancells parameter for transferring dictionaries
The screen capture isn’t helpful. Please upload some code or your .GH file…
– Dale
Dataset.gh (15.1 MB)
Please use this gh file
It seems to be working here in the latest Rhino 8.10 Release Candidate.
There is a Python component showing an error - not sure what that’s about.
topologicpy==0.7.42
How can I repeat what you’re seeing?
– Dale
if you add the parameter, “tranCells = True” , the window is not responding and i am getting the previously mentioned error
Yes it sure does. I see it starting a bunch of new instances of Rhino. Why?
What is “Topology.TransferDictionariesBySelectors” supposed to do?
– Dale
Yes, it does, its supposed to copy the dictionaries(key is “space_name” and value is “the space name” set on the centroids to the cells themselves.
Copy to what? All I see happening in lots of instances of Rhino are launched…
– Dale
I am trying to set a dictionary (space name like living room and bedroom) into the centroid of a room and then transfer it from the centroid to the room geometry itself. This is possible in Topologicpy, a spatial analysis python library.
i was told it uses the multiprocessing module for parallel processing in python. In windows it uses the “spawn” method to create new processes.
The “spawn” method isn’t going to work with Rhino.
You might contact the developer of the library for more details.
– Dale
okay, Thank you.
