I have a function that takes a single multiface brep and tries to get its outer borders, flatten those, make a planar surface from them, extrude the surface and return the extrusion - which should be a single brep. In the screenshots below, you see a breakpoint just before the function returns - you can clearly see that extru is a single brep and that it will be returned.
No problem to there, but when I return to the main function, the return value is a tuple that contains the brep and not a single item (the brep itself)…
No I have not… No commas - the screenshots above are WYSIWYG…
I have a couple of other projects that I need to work on first, so I haven’t gotten any further. In any case, for what I wanted to do - the function is only a part of it - things are not working correctly, so looks like I’m going to need different approach anyway. But I would be curious to understand why, I’ve never seen this happen before.
