Is it in a directory which is listed when you execute this on a button?
import sys
print sys.path
import sys
print sys.path
I also have a problem with placing this script on a button:
import random
def test():
Ids = rs.GetObjects("Select block instances to rotate", filter = 4096, preselect=True)
if Ids is None: return
vec = rs.VectorCreate([0,0,1], [0,0,0])
for Id in Ids:
pt = rs.BlockInstanceInsertPoint(Id)
ang = random.randrange(-180, 180)
rs.RotateObject(Id, pt,ang,vec)
if name == “main”:
test()
I placed it between
! _-RunPythonScript (
as it was suggested, however, it does not work (It just runs trough without giving me the opportunity to select anything…)… I runs fine in the editor tough…
any clues?
Thanks
Andreas
Hi Andreas - the solution is buried above -
Also, when using that ‘name’ and ‘main’ it is '__name__' and '__main__'
