Python script that behaves strangely
Below is attached a Python script that behaves strangely. The script puts the odds (long long X or Y) of the sides of a polylinea as in the attached image or any other.
If I click the side close to the edge (red circle) puts me exactly share if I click on side in center position (green circle) puts the proportion between one end and the point where I clicked like in the attached image.
Further strange thing is that: I close and then open the item again, drawing a Rhino polylinea, launch the script and I click on a side away from the edge puts the first precise altitude and then returns the first casino.
I wish someone would try to see what happens on other computers.
Ciao Vittorio
import Rhino
import scriptcontext
def GetCurvesAndEdges():
    Return segmento di polylinea , linea, edge
    filter= Rhino.DocObjects.ObjectType.Curve
    rc, objrefs = Rhino.Input.RhinoGet.GetOneObject("Seleziona segmento o edge da quotare", False, filter)
    if rc != Rhino.Commands.Result.Success: return rc
    pp=Rhino.DocObjects.ObjRef.CurveParameter(objrefs)
    print "c",objrefs.Curve()
    pt=objrefs.SelectionPoint()
    #rs.AddPoint(pt)
    a=Rhino.Geometry.Curve.DuplicateSegments(objrefs.Curve())
    if len(a)==0:
        segmento=scriptcontext.doc.Objects.AddCurve(objrefs.Curve())
        return segmento
    cc=[]
    for i in a:
        seg=scriptcontext.doc.Objects.AddCurve(i)
        param=rs.CurveClosestPoint(seg,pt)
        cp=rs.EvaluateCurve(seg,param)
        if rs.PointCompare(pt,cp,0.0001):
            segmento=seg
        else:
            cc.append(seg)
    rs.DeleteObjects(cc)
    return segmento
cc=GetCurvesAndEdges()
if rs.IsLine(cc):
    ps=rs.CurveStartPoint(cc)
    pe=rs.CurveEndPoint(cc)
    #rs.AddPoints((ps,pe))
    p1=rs.coerce3dpoint(ps)
    p2=rs.coerce3dpoint(pe)
    rs.AddPoints((p1,p2))
    rs.DeleteObject(cc)
    rs.Command("Dim W"+str(p1)+" W"+str(p2))
<a class="attachment" href="https://global.discourse-cdn.com/mcneel/uploads/default/original/3X/8/6/865e55131a9f8168d939d6572e133975d08bfefe.py">QuotaToccandoSegmentoPolylinea.py</a> (1.4 KB)
Problem Solved
import Rhino
rc, objrefs = Rhino.Input.RhinoGet.GetOneObject(“Seleziona segmento o edge da quotare”, False, filter)
print “c”,objrefs.Curve()
#rs.AddPoint(pt)
if len(a)==0:
return segmento
cc=[]
for i in a:
if rs.PointCompare(pt,cp,0.001):
segmento=seg
print “seg”,segmento
else:
cc.append(seg)
#rs.MessageBox(segmento)
rs.UnselectAllObjects()
#if rs.IsLine(segmento):
rs.SelectObject(segmento)
rs.Command("_Dim _Object")
rs.DeleteObject(segmento)
GetCurvesAndEdges()
@vittorio, i always get the dimension drawn between the startpoint of the segment and the picked point (S).
ciao,
c.
Hi Clement
I found the error. The below Python script is OK.
Vittorio
QuotaToccandoSegmentoPolylinea.py (1.5 KB)
Hi Vittorio, i´ve found that this whole script can be written using one line and still works the same:
_Dim _Object
:wink:
c.
