I have a script that prepares curves for my wire eroder, it sets the start point and a pause point for closed curves. The script has worked fine in V5 but in V6 the start point is in the wrong place when the script finishes,
I’ve found if I reverse the list passed to JoinCurves it works in V6 as before but this means I can’t use the same script for V5 and 6. Haven’t looked at whether JoinCurves or SplitCurve has changed.
if point:
#rs.AddPoint(point)
param = rs.CurveClosestPoint(curve, point)
#print "Curve parameter:", param
newCurve = rs.SplitCurve( curve, param )
if newCurve:
#newCurve.reverse()
curve = rs.JoinCurves(newCurve, True)
rs.DeleteObject(stpoint)
return(curve)
Here’s a screencast V6 first then V5
Mark
Edit added scriptSplitCurve.py (3.1 KB)
