Python problem with fRange floating values
Why does a 2.3333 appears? It should end at 2.0.
The goal is to set a size of x and y; and that within the size a resolution can be set wherein the size does not change, only the amount of points within the size as like a resolution.
It comes down to avoid the 2.3333, somehow it is overruled in my script.
python problem with fRange 01.gh (7.3 KB)
python problem with fRange 02.gh (5.9 KB)
def fRange(start, end, step):
    list = []
    list.append(start)
    temp = list[0]
    while (temp <= end):
        temp += (end/step)
        list.append(temp)
    list.pop(-1)
    return list
a = fRange(x, y, z)
frange() is a rhinoscript specific function. you can call it by using rs.frange(start, end, step). it is for numbers of the type “float”, hence the f in frange.
is this they type of thing you are after?
frange
def myFrange(x, y, z):
	vals = []
	for i in rs.frange(x, y, z):
		vals.append(i)
	if u:
		vals.append(y)
	else:
		pass
	return vals
a = myFrange(x, y, z)
Chris Hanley is correct,But you can also try your method,I made some minor changes.like this
Code:
    list = []
    list.append(start)
    temp = start
        temp += step
        if(temp<=end):
            list.append(temp)
        else:
            list.append(end)
    return list
a = fRange(x, y, z)
This is my interpretation of what you are trying to achieve. This gives the start value as x, the end value as y and the total number of steps (including the start and end) equal to z.
list = []
temp = start
qty = int(step-1)
list.append(start)
for i in range(0,qty):
temp += ((end-start)/(step-1))
list.append(temp)
return list
a = fRange(x, y, z)
