I’m writing a script where I need to find the intersection of a series of created section curves with the centreline (World XZ plane)… I’ve got the folllowing code, but get an error for “index out of range: 1”.
def curve_CL(curves):
points = []
plane = rs.WorldZXPlane()
for crv in curves:
int = rs.PlaneCurveIntersection(plane,crv)
if not int:
print "Error with plane-curve intersection"
points.append(int[1])
return points
I can see why this is - because the resulting point that I’m after is hidden inside a tuple, which itself is inside a list (see below from debugging)… but I can’t understand why this is… the help file info for the PlaneCurveIntersection gives the return as just a list, where the point should be at index [1].
Yes, that was a bit of code that I added to try and see what was happening, but your revision doesn’t change the outcome of the code… I still get the “index out of range” error.
The really annoying bit is that I can see where the error is coming from, but not how to avoid it.
Oh, sorry, spaced that one - the intersection function could return several intersection events, thus it’s a tuple of lists. So you need to iterate through the various possibly returned intersection events:
points = []
for crv in curves:
if int:
for i in range(len(int)):
points.append(int[i][1])
else:
return points
Now that the problem is sorted you should also call your intersection variable something else than int, since your current code hides the builtin numerical type int (:
