Python: placing statements behind each other
The following is possible.
try:
    if minX<minBbX: minBbX=minX
except: minBbX=minX
This is not possible, or is it possible?
try: if minX<minBbX: minBbX=minX
except: minBbX=minX
In Python, the try block is meant to test a portion of code for errors. The except block lets you handle the error.
Example:
try:
    print x
except:
    raise ValueError("The variable x is not defined")
I don’t get what you are trying to do here, but wouldn’t this be feasible with a simple if statement? Your code logic seems a bit redundant. If minX is smaller than minBbX, minBbX becomes minX, otherwise minBbX also equals minX, which could simply be written like this:
minBbX = minX
Btw, both code blocks that you posted above are pretty much exactly the same. O.o
Yes and it is always preferable to trap specific exceptions if possible, ie:
try:
    print x
except NameError:
Because:
https://realpython.com/the-most-diabolical-python-antipattern/
