Hi All,
Got a script to svg export closed curves working and hoped that the options used would be those that are set in the dialog when doing a manual export but it seems that it’s not the case, in fact the options are all over the place as I’m getting different results each time I run the script.
Having looked hard trying to find an answer to this question, the closer I could get was a suggestion that there was a need to dig deep into passing the options when invoking the comand inside the script.
Is there any documentation regarding how to find the options for SVG Export as it’s based on a dialog and there is no console feedback?
Any help would be appreciated.
Thanks
