Python: NURBSSurface to Surface / Normal
Using Python.
How do I get the normal of a planar NURBS surface? Is this possible?
Also how to I convert a planar NURBS surface to a regular surface so the normal can be accessed?
Hi Mike - if you use GetPoint() you can then use Surface.ClosestPoint, which will get you the parameters at that point, then Surface.NormalAt(parU, parV)
See also Surfsace.FrameAt()
Thanks. Is there anyway to convert a planar NURBS surface to a regular surface object?
I just noticed the NormalAt() method. Can I use that and pass 0,0 as the u,v parameters? I’m assuming here that u and v are relative to the NURBS surface object. Is that correct?
Hi Mike - you’ll need a valid pair of parameters for the surface - 0,0 might or might not be in the surface domain - probably more relaible to get the surface domain in U and V and use domainU.Min and domainV.min.
