I just started exploring multiprocessing in python outside of ghpythonlib.parallel.run(). I’ve run into some unexpected results.
My test script:
import multiprocessing as mp
import time
from PIL import Image as image
class myclass:
def __init__(self,integer):
self.integer=integer
self.result=None
self.image=None
def func(_index):
#this function uses PIL to generate a solid color image
#the purpose is to cause significant CPU load
myclasslist[_index].image=image.new("L",(2000,2000),0)
temp=[myclasslist[_index].integer*20 for k in range(2000*2000)]
myclasslist[_index].image.putdata(temp)
#myclasslist[_index].result is what I am testing
myclasslist[_index].result=myclasslist[_index].integer+100
print (myclasslist[_index].result)
return myclasslist[_index].result
time0=time.time()
myclasslist=[myclass(i) for i in range(10)]
pool=mp.Pool(processes=4)
mpresult=pool.map(func,range(10))
time1=time.time()
print(time1-time0)
print (mpresults)
print([myclasslist[i].result for i in range(10)])
In the end mpresults show the correct results, but myclasslist[i].result shows None. I read online that each process gets its own instance of my object, therefore when I do:
it does not stick. Is there a way to get it to stick so when I print in the end it shows the correct values?
And does anyone know how to get pool.map() to work with class methods()?
