Hello all,
I’m trying to automate a few things by exporting dimensions from python to text objects. I’m very new to python…
Test.py (1008 Bytes)
Hello all,
Hi @Sethaba,
you are trying to access a list index that does not exist. In the documentation you’ll see that rs.SurfaceArea() returns a list of 2 number values. Your script tries to acces a third value dimensions[2]
, which is out of range and causes an ‘index out of range’ exception.
If the object you want to get dimensions of is world-aligned, you could use it’s boundingBox
cheers,
Tim
bb = rs.BoundingBox(TextObject)
# for each world-aligned axis, get the bounding-box dimension
dim_x = bb[6].X - bb[0].X
dim_y = bb[6].Y - bb[0].Y
dim_z = bb[6].Z - bb[0].Z
Oh, I see. The issue with bounding box is if I have multiple objects to dimension, I have to select them individually. If there are 100’s that’s a real pain.
you can just iterate over all objects in a selection like so:
def main():
# get object selection
objs = rs.GetObjects(preselect = True)
if not objs:
print( 'abort' )
return
# loop over all objects in selection
for obj in objs:
bb = rs.BoundingBox(obj)
# ... rest of code that creates a text for each bb
if __name__ == '__main__':
main()
