[Python] Make Rhino View have focus
Hi All,
Given a Rhino View object, how do I make it the focus in the GUI? Specifically, my goal is to give focus to the first floating window in the project.
views = scriptcontext.doc.Views.GetViewList( True, False )
        for view in views:
            if( view.Floating == True ):
                # MAKE THE FOCUS
                print "found floating: ", view.MainViewport.Name
Any help would be greatly appreciated
Hi Ivo,
does this work for you:
for view in views:
        scriptcontext.doc.Views.ActiveView = view
-Willem
Thank you, Willem.
Here’s a working example for others:
    import scriptcontext
    # Open "Focus_Test.3dm" prior to running this script
    def FocusFloating():
        for view in views:
                print view.MainViewport.Name, "should now be the active/focused upon viewport"
    if __name__ == "__main__":
        FocusFloating()
Focus_Test.3dm (63.7 KB)
