How can I use isdecimal() on a string returned by PropertyListBox. I can’t get this code to work for some reason.
if results:
for number in results:
number = unicode(number, "utf-8")
if not number.isdecimal():
print 'Enter numbers only!'
return(None)
results = map(float, results)
Thanks Mark
Edited because the conversion from string to float didn’t work. The above code works on whole numbers but fails on decimal numbers.
