Python interpreter being set to the Rhino executable path
I’m currently working with the Python 3 component in Grasshopper, but I’m facing an issue with the Python interpreter being set to the Rhino executable path (C:\Program Files\Rhino 8\System\Rhino.exe). This seems to cause problems when importing external libraries like numpy, as the interpreter doesn’t recognize the correct Python environment.
I would like to change the Python interpreter used by the Grasshopper Python 3 component to a specific Python environment located at:
‘C:\Users\come1.rhinocode\py39-rh8\python.exe’
Here are some details:
  • Current Python executable: C:\Program Files\Rhino 8\System\Rhino.exe
  • Desired Python executable: C:\Users\come1\.rhinocode\py39-rh8\python.exe
  • Problem: The current setup causes ImportError when trying to import numpy, likely because it is trying to use a source directory instead of the correct site-packages from the environment.
Additionally, I have already tried several methods to change the Python interpreter using GPT-assisted suggestions, such as:
  1. Modifying sys.executable or using os.environ["PYTHON_EXECUTABLE"].
  2. Adjusting sys.path to include the correct site-packages directory.
  3. Reinstalling numpy and other libraries in the Rhino Python environment.
Unfortunately, none of these approaches worked. The Python 3 component in Grasshopper continues to default to the Rhino executable, and the import issues persist.
Could you please guide me on:
  1. How to change the Python executable (sys.executable) used by the Python 3 component in Grasshopper?
  2. Ensuring the Python 3 component correctly uses libraries installed in C:\Users\come1\.rhinocode\py39-rh8\lib\site-packages?
Any insights or solutions would be greatly appreciated. Thank you so much for your help!
Best regards,
Hello and welcome to the community!
What is the specific error you are seeing with numpy? Also which version of Rhino are you using?
