Python could solve this?
Hello Hello,
i’m working on a quite repetive work right now and i wanted to know if a python script could work to be able to do this task.
I need to adapte dimention to a plan that is quick i select the face and i move to the lengh i want like this.
but would it be possible to create an python script where you move it went back the surface to 0,05 for exemple in the other direction ? like the next image
Like this i could create a command who make the surface and move in the other direction of a constant direction in the same command !
Thank you so much for your help
Hi Julien - I am not quite sure I follow yet but maybe just a macro:
! _MoveFace _Pause -.05
to test / finetune the macro:
_macroEditor
Its not exactly that i would like to select point or face thats good to be able to move until the point i want and automatically it take the normal i did and move it 0.05 in the opposite direction. Its to create gap in my 3D. thank you so much Pascal
