The Python equivalent is
for i, pt in enumerate(pts):
EDIT ignore that - sorry I was looking at the for loop
I don’t understand…?
I will try to explain the problem more explicit.
The code I posted does not start with the string from start_point as you can see inthe picture. The green coloured point is just one of the points inside the point array. Maybe someone can help me to modify the code, that the searching starts from my start_point0
Can you share a (preferably simplified, format rhino 5) file + py file with everything you need to make the code run?, ie points, definition of start point
Tester.gh (42.4 KB)
Find attatched my gh file with necessary content internalised. For better orientation the important script part is written between two big diamond sign rows.
poolunused is a list of points I want to work on. My start_point0 is an extra point that is not stored in poolunused.
Thanks a lot!
can u work with that?
Hmm - what happens if you put counter=0
before your while loop? You are currently resetting it to 0 at every step
still the same problem
Like this?
poolunused = sum_attractors[:]
shortestpathfromattractors = []
counter = 0
while len(poolunused) > 0:
for pt in poolunused:
if counter == 0: start_point0 = start_point0
else: start_point0 = shortestpathfromattractors[len(shortestpathfromattractors)-1]
ClosestPt = rc.Collections.Point3dList.ClosestIndexInList(poolunused, start_point0)
shortestpathfromattractors.append(poolunused[ClosestPt])
poolunused.pop(ClosestPt)
counter +=1
Hi @STUDENT_F,
You can solve this with a recursive function!
Your start point is automatically added to the path points as long as it is part of the Points that you input!
consecutive_closest_points_v1.gh (9.5 KB)
That is a well organized script that works brilliantly for me. Thanks a lot for your support and time!
Do you also know how to get start and end point of each pair?
Sure, simply make the following changes to the script:
import Rhino.Geometry as rg
def find_closest_points(start_point, point_cloud, max_recs=float("inf"), _depth=0, _path=[]):
"""Recursively searches a point cloud for consecutive closest points.
Args:
test_point: A point to search from.
point_cloud: A point cloud to search.
max_recs: An optional maximum number of recursions.
_depth: A current recursion depth.
_path: A current nested list of point pairs.
Returns:
The nested list of consecutive point pairs.
if point_cloud.Count > 0:
pt_cloud = point_cloud.Duplicate()
closest_idx = pt_cloud.ClosestPoint(start_point)
closest_pt = rg.Point3d(pt_cloud[closest_idx].X,
pt_cloud[closest_idx].Y,
pt_cloud[closest_idx].Z)
_path.append([start_point, closest_pt]) # Change this...
pt_cloud.RemoveAt(closest_idx)
if point_cloud.Count > 0 and _depth < max_recs:
_depth +=1
return find_closest_points(closest_pt, pt_cloud, max_recs, _depth, _path)
return _path
# Get the start point
start_pt = Points[iStartPoint]
# Create the point cloud
attractor_pts = rg.PointCloud(Points)
# Get the consecutive point pairs
pairs = find_closest_points(start_pt, attractor_pts) # ... and this
print pairs
# Flatten the point pairs list (for the polyline construction)
path = [pair[1] for pair in pairs] # ... and this
# Outputs
a = path # ... and finally this
When flattening the list of point pairs, you may wander why we simply keep the second item from each pair. Well, it has to do with the start point! If the start point is a member of the attractor points, it finds itself as the closest point at the very first recursion.
In the first script, this was great, since the first point to append to the path list was the start point anyway.
However, in pairs script, at the very first recursion, the start point finds itself as its closest point, and thus forms a pair with itself. At the second recursion, it looks for another closest point, but this time, its doppelgänger was already deleted from the point cloud, so it finds another point this time.
Example:
Pairs list:
[[start_point, start_point], [start_point, other_point0], [other_point0, other_point1], … [other_pointX, other_pointY]]
Flat list:
[start_point, other_point0, other_point1, … , other_pointX, other_pointY]
Furthermore, you can also limit the length of the path, by limiting the maximum recursion depth that is currently set to infinity. The maximum recursion depth is mainly a security parameter that you can set to prevent huge numbers of recursions though.
Ok Python version:)
def infinity():
i = 0
while True:
yield i
i+=1
for i in infinity():
if i == 1000000:
print('done')
break
A rare example of Python being much more verbose than C
Thank you. Unfortunatly when I print pairs, there are no pairs. I need branches with two elements. Start and Endpoint.
So at the end: listofpairs = [[a,b], [b,c], [c,d], …]
When printing from the GHPython component, there should be point pairs (see updated above code).
Do you want to output the point pairs as a tree with a branch for each pair?
Yes I found them. Thank you.
Can you help me with this part of code? Does not work correctly. Segements is a list that stores the start and endpoint so it looks like this segments = [(a,b), (b,c), (c,d)]
Now I want to draw a line between every tuple start and end point. Just want to connect for example a,b
segments = []
start_pts = [i[0] for i in segments]
end_pts = [i[1] for i in segments]
print start_pts[0]
for j in start_pts:
for d in end_pts:
line_start_to_attractor = rs.AddLine(j,d)
How abou:
for a, b in segments:
rs.AddLine(a,b)
yes but i want to draw a line between every tuple values that is stores in segments, so line a-b, line b-c, line c-d
Yes that is what my code snippet should do…
The first line unpacks the tuples. The second creates the line. It is equivalent to:
for tup in segments:
a,b = tup
rs.AddLine(a,b)
