Python add IsSubD
Can you add IsSubD for Rhino python?
Hi @Alen_Russ
You can check if your object is a SubD with isinstance using RhinoCommon:
isinstance(subdobj, Rhino.Geometry.SubD)
Hi @DavidLeon
Thank you for your help. I dont know how to use in python editor. when I test to select the SubD object that show It is not a SubD.
import Rhino
subdobj = rs.GetObject("Select the SubD object", preselect=True, select=False)
if isinstance(subdobj,Rhino.Geometry.SubD):
    print "It is a SubD."
else:
    print "It is not a SubD."
rs.GetObject() returns a guid, you need to get the geometry that represents that guid in the document:
import Rhino
subdguid = rs.GetObject("Select the SubD object", preselect=True, select=False)
#get the geometry from guid
subdobj= Rhino.RhinoDoc.ActiveDoc.Objects.Find(subdguid).Geometry
else:
Thank you
