Pushpull skewed geometry
pushpull geometry isnt perfectly semetrical like the geometry i projected to thr body. Why? and how can i fix it? i made the model in subd and then converted to nurbs. what gives
hard to guess from a screenshot.
post a file or partial geometry…
you can drag and drop a .3dm file to the post / edit window.
(up to 10 MB works well maybe even more…)
Game Controller2.3dm (2.1 MB)
the curve you projected has a radius of 0.03 inch.
the document tolerance is 0.01 inch
one rule of thumb says, that document tolerance should be at least 1/10 of the smallest detail.
increase document tolerance to 0.001 and push pull does the job.
_documentProperties → units
in general document tolerance should be set at the beginning of a model - and should be kept. Changing the tolerance is not considered as good practice.
can i make it permanent? can i change it now? do i have to set it every time? this is just practice. nothing important
start with the correct template and set it default.
small objects millimetres / inch
Thanks for your help
