PushPull multiple faces in given direction
Would like to extend the lower peaked roof upwards.
I was able to PushPull twice, once for each side, but somehow this should be possible in one go? Also, it would be nice to be able to move the peak all the way up to the top, but it won’t extend any further.
PushPullMultiple.3dm (2.2 MB)
yep, that is a current limitation… one Push pull at a time.
@Joshua_Kennedy is the man to answer if multiples are possible-
Agreed that it would be nice to use the PushPull on multiple faces in one command. Can this be added? I can’t even select a face by dragging a window around the face I want to PushPull.
In the MoveFace command, which I use all the time, I can select multiple faces. But the nice thing about Push/Pull is that it remembers the previous input distance. MoveFace does not. This would be a nice addition to MoveFace & MoveEdge.
Agreed, again @Joshua_Kennedy would have to chime in on the feasibility of doing this.
PushPull on multiple faces is possible. The issue is open here. I’m hoping I can implement at some point but I don’t have any timeline.
Yes, I found I’m just not using Push/Pull because of this, and went back to using MoveFace/Edge.
(I find MoveFace/Edge becomes problematic in a complex model, shifting things around a lot, eventually some geometry becomes slightly non-orthogonal.)
