Pushpull bug?
Create basic spline
Extrude up and pushpull
Push back
The more the spline is complicated the worse results i get
hi @ivan.galik I’m not getting those singe surface artifacts here. It does in some cases break, but differently. Pls always try to add the file that is showing this, even though it might look super simple.
pushpullbug.3dm (253.5 KB)
i suspected angle tolerance but it does not seem to affect
Thanks, RH-76148 Pushpull fails to remove all
