No, it just doesn’t sound right. Luckily undo unpurged it.
I have a custom tick on all my dimensions. It got purged when I purged unused blocks. This might be considered a bug?
Wish that worked on my dog!
Hello - I suppose one thing to check is, did the incoming blocks bring in annotations with the same names but different attributes (tick/no tick) ?
There are some imported blocks (assuming that’s what you mean…) from drawings created from the same template, yes. But there’s only one block in the host project named “Tick” and only one instance of each of the DimStyles that use it. After the purge, the field for the flyout menu for those DimStyles’ user arrow choice is blank and Tick is absent from the list of blocks to use.
