Purge canvas from unknown used plugin
Hey there,
Is there a way to remove an instance of a component from a computer that doesn’t have that component? In short, I’d like to delete the component on top, without installing the plugin.
This comes from the fact that the ghosted component is an ancient version of a plugin that isn’t available on food4rhino anymore. :face_in_clouds:
Meh
For anyone having this “issue”, a simple copy paste in a new file does the trick…
You can also select everything with Ctrl-A and then deselect everything with window selection, and then press delete.
