Does anyone have an existing script to pull a curve to the underlying untrimmed version of a surface? In this case, the surafce is mainly for reference
This would save copying the trimmed surface, untrimming it, running pull, deleting the untrimmed surface.
I did start trying to make a DupSrf command which would make an untrimmed copy of a surface - possibly also extracting from a polysurface at the same time intelligently.
Works nicely. I will try and update it so it works a little more like pull, with the option for multiple curves and subsurfaces from a polysurface.
Although that could maybe be messy output wise if you pull to two different untrimmed surfaces… so simpler is probably better, with just multiple curves at least.
