Pull Point working on X axis instead of vertical axis
Hey Guys, Im working on this facade system that I would like to slowly become more “Hollow” as it reaches the edge of the wall. I’ve managed to get the premise of it working, but I am having trouble getting this pull point to work in the Y axis instead of the x Axis. I will attach my script as well as what i’m getting now, and what I want to happen! Any advice would be greatly appreciated :slight_smile:
But you didn’t :question:
3. Attach minimal versions of all the relevant files
Didnt try rebuild the script.
But most likely problem is dataTree structure from your centroids. Make sure its structured in rows and columns. Try to flipMatrix to change direction.
And also you need one number per branch (from pull point), so probably manipulate only first item on each branch with attractor. And make sure DataTree structure of distances and curves is same
if you don’t want the effect to be calculated by branch, then you should flatten the Bounds input
you have just joined the forum, welcome on board, attaching your script means to drag the .gh file on the canvas, not attaching a screenshot of the definition :slight_smile:
