Pull point wish
I wish that the “pull point” component had an extra output that would give the index of the relevant geometry the point is pulled to.
For example, if the “Closest only” option is chosen, then it would give the index of the geometry closest to the point(s).
If “All” is chosen instead, then give the index of all the geometries in the same order as the resulting pulled point and distance.
This would require less “post-fiddling” to retrieve the geometry we are interested in.
