Pull mesh vertices to another mesh
I have a retopologized quad-only mesh, and I’d like to move it’s vertices back on the original high-rez mesh.
Is that even possible in Rhino ?
In gh you can do mesh closest point. Unless you want a Rhino only option.
Hello - in the V7/WIP you can turn on points for an object and Pull them to a surface or mesh.
here is a python for V6
import scriptcontext as sc
import Rhino
def PullMeshVerts():
    def filter_first_object(rhino_object, geometry, component_index):
        if rhino_object.Id == id1:
            return False
        return True
    id1 = rs.GetObject("Select the mesh to change.", 32, preselect=True)
    if not id1: return
    id2 = rs.GetObject("Select the target object.", 8+16+32, custom_filter = filter_first_object )
    if not id2: return
    m1 = rs.coercemesh(id1)
    m2 = rs.coercegeometry(id2)
    for n in range(m1.Vertices.Count):
        m1.Vertices.SetVertex(n,m2.ClosestPoint(Rhino.Geometry.Point3d(m1.Vertices[n])))
    sc.doc.Objects.Replace (id1, m1)
    sc.doc.Views.Redraw()
if __name__ == '__main__':PullMeshVerts()
Thank you gentlemen.
Always wondered why control points couldn’t be pulled or projected on another geometry in Rhino…
I failed to find that GH component ; now it’s child’s play :
