When I use the pull command to pull a point to a surface, the user text is lost. This didn’t happen in Rhino 5.
While working in a Work session file, if a block is copied using the Copy command, the newly copied object is exploded for some reason. And also if a Rhino 5 work session file is set to open in Rhino 6 as a default program, the file is detected as a 3D model file and not a worksession.
I’m not sure if these are bugs, but if there are any settings to prevent the behaviour, please let me know. Thanks.
