ProxyBlock — LOD proxy management for Rhino 8
Hi all, I’ve released ProxyBlock, a plugin that manages heavy block/mesh/brep/extrusion/subd geometry in three LOD levels (Original / Medium / Low) with instant switching.
Key properties this design enables: - Position, rotation, non-uniform scale, mirror preserved - Instance-count-independent switching speed (verified: 1001 instances = ~110ms, O(1)) - Purge-safe: inactive LODs stay referenced by Master - Data survives in .3dm when plugin is not loaded (UserString + JSON, not custom UserData)
Commands (11 total, PB prefix): PBCreate, PBUpdate, PBSetOriginal, PBSetMedium, PBSetLow, PBRegenerateMedium, PBRegenerateLow, PBRegenerateAll, PBPanel, PBRestoreOriginal, PBAudit
Happy to discuss the architecture or answer questions.
Adding a demo video to show the switching speed in practice:
This is 1001 instances switching between Original, Medium, and
Low LOD levels — each switch takes about 110ms regardless of
instance count, since only the Master block definition is
modified (not each instance).
Happy to answer any questions about the implementation.
ProxyBlock Trial is now available — a free version for anyone
who wants to try it before buying.
Trial limitations:
  • Max 3 ProxyBlocks per file
  • PBAudit and PBRestoreOriginal are not available
  • Everything else works exactly the same, including full
    switching speed regardless of instance count (the 1001-instance
    demo above applies to Trial too)
It installs as a separate plugin (“ProxyBlock Trial”), so it
won’t conflict with the full version if you already have it.
Download: Proxy Block | Food4Rhino
Full version ($10, unlimited ProxyBlocks):
I bought the plugin and I think it could become very useful in the future, however I would like to add an option for a 4th state, which the user can define.
e.g. for some trees with let´s say 500 000 polys even 10 % is too much, so the user could specify e.g. 1% or even 0,5 and end up with something useful having 5000 or 2500 polys.
Another nice thing would be to have bounding box (which already exists as a native display mode…) as a 5th option.
You could also enable the user to alter the existing modes with 50% and 10% to user defined values.
Best
Andreas
Hi Andreas,
Thank you for purchasing ProxyBlock, and for the detailed feedback
— this is exactly the kind of real-world case I need to hear about.
The 500k-poly tree scenario makes total sense. 10% still being too
heavy for very dense organic geometry (trees, foliage) is a good
point I hadn’t fully accounted for.
A few thoughts on your suggestions:
  1. Custom reduction percentage (user-defined 4th state) — this
    seems like the most valuable addition. I’ll look into adding
    an editable percentage field per ProxyBlock.
  2. Bounding box as a 5th LOD option — good idea, and since Rhino
    already has this as a native display mode, this might be
    straightforward to wire in.
  3. Making Medium/Low percentages user-editable — this pairs well
    with #1, might implement them together.
I can’t promise a timeline yet, but I’ll start looking into #1
and #2 first since they address the case you described directly.
I’ll update this thread when there’s progress.
Thanks again for taking the time to write this up.
Update: added Custom LOD and Bounding Box support based on
feedback.
Custom LOD lets you set any reduction percentage per ProxyBlock
(not just the fixed Medium/Low presets) — useful for dense
organic geometry like foliage where even 10% can still be too
heavy.
Bounding Box adds a fifth level: swaps the geometry for its
bounding box, generated automatically from the Original.
New commands: PBSetCustom, PBRegenerateCustom, PBSetBoundingBox
original geometry
custom low (1%)
Both integrate with the existing Master indirect reference
design, so switching speed is unaffected regardless of instance
count.
@walther
— this should cover both points from your post.
Let me know if the custom percentage workflow feels right or if
you’d want it exposed differently.
Existing users: just re-download and reinstall, no license
changes needed.
