Hey Folks,
Anybody experience anything similar to this?
Trying to render a turntable animation using the ProRender plug-in. Everything works great in the other display modes but ProRender seems to be producing an image that’s tilted slightly (If you zoom in close you can see the yellow selection doesn’t match with the white model poking out the corners). Resulting animation is slightly askew and has a noticeable inflection point that tilts/skews in the opposite direction once the camera gets around 180 degrees.
I’m able to get a single normal render only once I rotate the view slightly slightly, that seems to shake it out of its lopsided state. Otherwise, the view loads askew and goes back to being askew once RecordAnimation is run.
Appreciate any and all suggestions!
Cheers,
G
