Is there a way to change the DPI of the interactive viewport of ProRender?
Currently it is always rendering the viewport resolution, however usually that is way too high for some tests and interactive workflow… Obviously, one can decrease the viewport size, but then the picture gets super small.
Sharpness is the ‘pixel size’, responsiveness does progressive resolution refine towards the viewport resolution divided by the pixel size set in sharpness.
I forgot to update this post last week. The current version of ProRender (1.0.0.7) has the sharpness and responsiveness options available in the plugin options.
@Joshua_Kennedy maybe the device you redacted is the new PRO W6800? If so, you could let us know since it is officially released now. Maybe you used the color blue intentionally
