Proportionately fill a space with a grid
Hi Everyone! I’ve run into a problem that I can’t seem to conquer. I am trying to arrange the array on the right (blue) within the path on the left (green) in a way that it snakes along the center and gets wider and skinnier in relation to the width of the path. Can anyone offer guidance on how to approach this?
Charlie
Nevermind! Figured it out!
So, what was your answer?
I was originally trying to flow along a surface that I had built using the Sweep2 command. I instead constructed one using Loft and it created the proper surface construction for the FlowAlongSrf command.
