Properties window material selection missing scroll
If I select an object, then attempt to change its material through the properties window in a file that has a whole bunch of materials, there is no scroll bar on the side of the pull down material menu, so I can’t get to the materials further down on the list.
Thanks,
Sam
I’m not seeing this here in
Work In Progress
(6.0.15022.19041, 1/22/2015)
Here’s a quick test… Do you get the scroll bar in this file?
Mat_scroll.3dm (27.0 KB)
Actually, when I open your file, it only opens with one material. Here is what I’m seeing on my side with a file with a bunch of random materials after importing a bunch of stuff:
How about if it’s docked? I’m not sure why you only see one material but one thing at a time.
@andy , do you have any ideas here?
