I have a weird bug/ problem with my properties panel. I will try to explain it in written text as good as i can.
When i select text or a hatch the properties panel opens in the middle of my screen as a floating panel, this is something i do not desire because i have this panel in my right side bar.
The moment i have this floating panel my sidebar panel has a empty colour fill and doesn’t show any information.
It is really annoying me at this point because i’m drafting at the moment.
I tried running rhino 6 (windows) as a Admin and reinstalled but the panel keeps floating on me.
I look forward to your reply’s and kind regards to reading my thread,
@roderode043, you may want to try with Vray disabled, just to eiliminate that variable - disable Vray in Options > Plug-ins page, then close and reopen Rhino.
Hello - please also try with ClippingBox disabled in Options > Plug-ins page (Restart Rhino) and if that does not sort it, can you please make the bad thing happen, and then copy paste the command history text here -(F2 key, CommandHistory, for command history).
First dimension point ( AnnotationStyle=Millimeter Small Object Continue=No Baseline=No ): _Pause
Second dimension point: _Pause
Dimension line location (offset distance) ( Horizontal Vertical ): _Vertical
Command: _Dim
Command: _Dim
Command: _Dim
Command: _Dim
Dimension line location (offset distance) ( Horizontal Vertical ): _Horizontal
Command: _Dim
Command: _Dim
Command: _Dim
1 linear dimension added to selection.
Select annotation to match
8 curves, 4 linear dimensions added to selection.
it happened with al these
were you able to find anything? i still have the bug.and even after reinstalling rhino twice it still exists.i does not seem to occur with rhino 7 WIP but here i have other bugs that make drafting troublesome.
