Hi all,
I wonder if someone might be able to provide some advice on a Grasshopper/Python related item?
The scenario is that (as part of a larger plugin) I am building out a GHPython component where I’d like to able to accept many different types of inputs in single node. This includes Panel-Strings/Numbers, Grasshopper-generated-geomerty, and Rhino-generated-geometry. In the case of Rhino-generated-geometry inputs, I’m also trying to pull in the UserText from the Rhino scene (if any).
So - in general, I think I have a solution that works ok so far. The main issue is that in order to allow for so many input types, I need to keep the Component’s input-node type-hint set to ‘No Type Hint’.
This poses some challenges when it comes to getting the Guid and the UserText of Rhino-side objects. In order to try and handle that and get the Guid’s of any inputs, I’m currently walking through the Input Node’s VolatileData and grabbing the ReferenceID for each item input object. So roughly like:
def get_input_guids(_input_index_number):
guids = []
for _ in ghenv.Component.Params.Input[_input_index_number].VolatileData[0]:
try:
guids.append(_.ReferenceID)
except AttributeError:
# If input doesn't have a ReferenceID, its probable a Panel text or number input
guids.append( None )
return guids
So I’m wondering:
- is this the ‘right’ way to do something like this?
- Is there any risk / downside to using the VolatileData input in particular? I am not very familiar with this property, and I wonder if perhaps there is some area where it might cause some issues down the line? It doesn’t seem that there is a ton of documentation for this property - to unsure about its use and limitations?
- Are there scenarios in which this property would become unreliable for some reason? In particular, accessing the [0] index item makes me wonder if I’ll be missing something in some other scenario? Not sure I understand that part. Maybe when the user Ctrl-Z 's or something in Rhino for some reason?
- Are there easier ways to allow for inputs of text, GH-Geom, RH-Geom and get the Guid of any Rhino-objects, that are already built in that folks know of that might be a better method?
I’ve attached an example GH file here for reference with a version of my current working implementation. Any advice is always much appreciated.
thanks!
@ed.p.may
input_organizing.gh (12.4 KB)
