I was developing my command to call “ProjectToCPlane” internally but it never get through the command. Feels like I need some special trick before calling ProjectToCPlane… Can you help me out?
Rhino.DocObjects.RhinoObject recentObject = doc.Objects.MostRecentObject();
if (recentObject != null)
recentObject.Select(true, true);
//bool result = Rhino.RhinoApp.RunScript("_-ProjectToCPlane Yes", true);
Rhino.RhinoApp.RunScript("! _-ProjectToCPlane _Pause _Yes", true);
//r = Rhino.RhinoApp.ExecuteCommand(RhinoDoc.ActiveDoc, "_-ProjectToCPlane _Yes");
doc.Views.Redraw();
I tried ExecuteCommand, -ReadCommandFile, RunScript and RunScript only showed “_ProjectToCPlane” on prompt but still nothing happens…
While if I type this command(totally same script) manually in Rhino, perfectly works.
