Projecting text onto surface issue
I have a strange behavior using the srfMorph. Im fitting a text into a box.
If i use a flat rectangle it works fine without issues. But here im using a surface from a lofted object where the Z is not the same for all points of the surface i am mapping to.
If i use the (non-flat) rectangle, the text outline goes outside the box! If i use an offset from the rectangle, the text is flipped (but i checked the points which are the same)… Im lost…
How do i unflip the curve (i know i could rotate it but feels like a hack - not elegant.)?
text framing or oriented issue.gh (23.1 KB)
Thanks for your help.
The target surface is trimmed , you can recreate it than use Map to surface.
shift list points to change text direction
scale bounding box to change text size
text framing or oriented 2.gh (15.3 KB)
Thanks @anon39580149, my first attempt was with MaptoSurf but couldn’t manage the Target part…
Thanks very very much!
So i added a fillet to the shape from where the frame is extracted and now the text is flipped mirror way!
If i shift the list by 4 instead of 2, the text is only flipped on the x axis instead of xy, but i couldn’t find the right offset to get the text to orient correctly.
The solution was adding “reverse list” after discontinuity and plug that directly into Polyline. Almost asked for help! :slight_smile:
It’s better if you post the final file ; you posted a simple example and there are many solutions but maybe you have another case which need a new solution
Gosh, so embarrassed i put this reply in the top board :frowning: instead of the reply here! No idea how i got mused into that! Appologies!
Well, being on holiday from my regular work (IT storage engineer) to work on my cnc and this ever longer knife project; so, i needed to spend time to review my model piece by piece (each day a major improvement) - I found out i had ‘bug’s’ or missing “capping” early in the model when i split a capped loft but missed the step to recap (and remove previous cap) which caused cascading issues. After i capped the volume from of which the ‘text’ face was extracted from… and now it works (although im sceptical about the fillet black thingies in the picture below)!
Otherwise i had open breps and couldn’t figure out why i couldn’t do boolean diffs. But i finally isolated the issues while making an example file to post… Re-simplify the 5th time this week - i wouldn’t learn GH if i didn’t try this myself and just expected the easy answers - almost posted 3 questions on the forum but managed to rethink my approach when describing the issue! :roll_eyes:
In brief the orientation of the surface coming from the discontinuity function/module is shifting the face orientation depending how i affected the model upstream! And if i use a hexagon or an octagon, i have a bit of face finding and list shifting from the disc. function to orient the text/graphic right in relation to the knife’s handle. Adding a second surface (1 more item slider connected to the list item that selects the face) also i causing problems but challenge for later - i did what i needed to do which is control it!
aha, noticed i need a fillet for the inside box! :slight_smile:
Thanks for the subtle insight @anon39580149 :wink:
