Hello, I’m trying to project this helix of a fixed pitch onto a this baseballbat mesh. I’m hoping to use this projected curve XYZ coordinates as a tool path on my lathe later on.
This thread seems to be exactly what I want.
https://www.grasshopper3d.com/forum/topics/map-helix-corkscrew-to-mesh-object
However, upon opening the .gh it appears sweep2 can’t be found while opening it? I do have sweep2 under surface-> Freeform -> sweep2 That post is from 2011, it appears Rhino 6 had an issue with sweep2 after reading other posts?
I have also tried using Mesh+ “Map Curves to Mesh” with no luck. What am I missing?
Thanks!
HelixBat.gh (19.2 KB)
