Project to Surface tool missing?
Working through a tutorial from Rhino 4 for windows, and it refers to using Project to Surface, yet I can’t find a corresponding icon on any tool pallet nor can I find it when typing Project in at the command prompt.
Are you looking for the “Project” command? Are you trying to project a curve to a surface?
Yup, apparently some of the command names have either changed in various versions of the windows version, or they have changed in the Mac version. Not the first time I’ve ran into something in a windows based tutorial that wasn’t named the same on the Mac version.
There’s definately stuff that works differently than it did in v4. To be expected, just adds to the learning curve when trying to figure out how to do things.
IIRC, the Project command hasn’t changed its name since Rhino 1.0 or earlier. Don’t confuse the tooltips or the menu items (which have longer explanations) with the actual command line command name…
That’s probably true, but not so much that the command name/sequence is unrecognizable…
–Mitch
