Project to mesh problem
In the attached file, projecting the 7 curves to the mesh results in 38 curves that have gaps in between, if you zoom in on most of the gaps, you will see that the end segments are doubled back on themselves in some cases, making the curves non-joinable easily… You can explode the projected curves and do a SelDup to find these bad sections (24 in number). Don’t quite know where the problem lies in this case…
Thanks, --Mitch
ProjCrv.zip
Hi Mitch- I see it, thanks.
