Thanks, correct keywords prevented me from finding this.
Im trying to accommodate it for me but just cant. His shade was âflatâ, mine are ribs in an array so his definition seems to just intersect mi brep.
You mean incorrect key words? Like âprojectâ⌠But you donât really think youâre the first person to encounter this problem, do you? So why give up searching for an answer so quickly when there are many, MANY examples of this common problem in the forum archives?
Finally, if you posted a model with your question, as recommended, the answer would be specific to you and save you the struggle of adapting someone elseâs code.
I understand you point. I sometimes feel like that when moderating other forums.
I did not use the same wording as that of the OP suggested. Lasercutting is not even an actual word plus im not looking for slicing ( i have my own slices already ) thus limiting the scope of search. Text inside that post also does not reference near my situation but i did try to learn from it thus the 2h delay in my response to the suggestion.
I do agree that uploading my definition would had help and im embarrassed by not doing it from the start. I have doe so now.
I appreciate the time and help the forum can provide.
Ok, tomorrow Iâll have a look on it.
btw for the future: just add grasshopper in google before your search words - Even with âgrasshopper lasercuttingâ you get many threads and also YouTube tutorials
For the future: if you just have 3 contours and one of them 12 times the same, itâs faster you do it manuallyâŚ
Because all ribs are the same. I just rotatet the first one back to xy plane, so you could also use every other definition out there.
Btw: If you cut both contours with the same size, your ribs wonât be like in the model. They will be closer to the center.
you want the Orient component⌠Inputs are the geometry to be oriented, the planes that the geometry are on and the planes where you want them oriented to.
I learnt about Orient from using the Bowerbird plugin which is great for doing waffle slices of shapes. The examples show how to orient the slices onto a plane for export for laser / water / CNC etc.
