Project Build Error
An error occurred when I built my project. error : Required file is missing“”
And I don’t think my configuration property page is wrong, I can’t find the problem. Thanks!
//Joann
Hi @15951991225,
This isn’t enough information for us to provide any help.
Is this a project that has been working that no longer works?
Is this a new project, generated using the Visual Studio project wizard?
Are you porting an older Rhino plug-in project to the Rhino 5 SDK?
Any additional information you can provide might be helpful.
Thanks,
– Dale
Hello Dale! this is a project that has been working that no longer works. And I create a new project, generated using the Visual Studio project wizard., the same is true! I haven’t used VS2010 for a long time, I just downloaded Rhino5 and Rhino5 SDK
I reinstalled VS2010, then this problem was solved!
