Hello dear subscribers …
I want to project a a 3d curve on a d brep I got closest point of divided nurb curves and with the closest points I interpolated them again but with doing this some curves which are out of the frame are missing … any one knows what is the better way?
make the curves smaller so they are not out of the frame or choose an appropriate mapping method
Hi dear @René_Corella
thank you dear friend I can not change the curves and make them smaller they are the result of analysis … and the problem is that exactly that what is an appropriate mapping method for doinf this?
Have you tried Pull Curve?
Hi dear @johnharding
thank you for your answer … whether I dont know how to work with that but I would try
Bests
thank you so much
