Progressive Scaling
I wondered if there is a way to create progressive scaling like on the uploaded image. I created the comparison by hand.
I played with the different scaling features but I couldn’t get the scaling to be progressive (like a gradient) as it is in the vertical lines. <img src=“https://aws1.discourse-cdn.com/mcneel/uploads/default/original/3X/3/e/3e19039e89d075cf2a880affffdb088d8dd09c83.JPG” width=“690” height="4
Play around with the stretch command.
Also, cage edit with just a line as your cage is cool and offers more control.
Hi Anton - CageEdit with a line as the control object, across the width of the pattern - ChangeDegree on the line to say 3 before using it as a CageEdit control, and move the resulting curve control points to scale.
Pascal,
thank you. CageEdit worked.
Thank you for your suggestions. CageEdit worked but I also like what the Stretch can do.
